Price: $45.90 - $35.90
(as of Sep 08, 2024 13:15:16 UTC – Details)
UPGRADE FEATURES:
Based on MD-090 crank radio and customer’s feedback, we’ve optimized and upgraded a lot of features in this MD-090P emergency weather radio with 6000mAh battery.
– NOAA weather radio with 7 NOAA channels to get the latest weather and hazard information;
– The hand crank radio flashlight cell phone charger with a 6000 mAh rechargeable battery, which charges more than one smartphone in the emergency;
– 4 Ways( Micro USB charge, Solar charge; Hand crank; Rechargeable Battery ) to keep the hand crank generator on power;
– The electricity label will notice you clearly the electricity of emergency radio;
– The flashlight radio with a super-bright 3 mode flashlight for any dark places you are in;
– Motion sensor reading lamp for you get up in the mid-night to avoid waking your family;
7 NOAA Weather Channel
This emergency crank radio with 7 NOAA channels to get the latest weather and hazard information like hurricanes, tornadoes, and so on. Earns a critical time for you to get full preparation advance, keeping you and your family safe with this emergency weather radio.
6000mAh Emergency Power Bank
Our Emergency weather radio provides 6000mAh power, which is twice or even four times that of other weather emergency radio, for charging your cellphone or any other USB device via Micro-USB cable directly in emergency.
Emergency Weather Radio with SOS Alarm
If you are in emergency, please don’t panic. SOS Alarm with flashlight red light can help to keep you feel safe while you are in need of help and nobody is around you. Long press the SOS BUTTON for 3S to ask for help.
FOUR Charging Methods To Keep Solar Crank Emergency Radio Never Power Off.
Solar Charging
It may take 140-150 hours to fully charge the emergency radio via the solar panel, which is mainly used to protect the rechargeable battery.
Micro USB Charging
It’s the best, quickest charging way for the emergency radio. It takes about 7-8 hours to fully charge the device with provided Micro USB cable.
Hand Crank Charging
1min of continuous cranking the solar crank radio at 130rmp in a clockwise or counterclockwise direction can support over 30 minutes of light or 5-6 minutes of radio work.
The hand crank radio also could be powered by 2PCS Rechargeable Batteries that you can easily purchase in your local convenience store or Amazon store.
Super-Bright 3 Mode Flashlight
The emergency flashlight radio made by high lumen LED, provide 3 modes: Dipped Beam, Far Beam, Far&Dipped Beam, which will be a great help for you in camping, hiking, and so on.
The farthest lighting range exceeds 20 meters
Motion Sensor Reading Lamp
A reading lamp with a Motion sensor will greatly help you. If you wake up in the mid-night, please put the switch to “AUTO”, it will turn on automatically when motion is detected and turn off after 30 seconds to avoid waking your family.
Specifics Of Portable Radio
Size:6.3 x 2.48 x 3.19 inches
Weight: 13.6oz (380g)
Power Source: 6000mAh / 3.7V rechargeable
LED Flashlight: 1W / 135LM(Max)
The portable size of the 6000 mAh emergency radio, which is convenient for you to carry for camping, hiking, and other activities
SELLER PROMISE
– 30-Day Money-Back Promise;
– 18-Month Replacement Promise;
– Lifetime Support Promise.
Your voice drives us to be the best. If you are not satisfied with this NOAA weather radio, we can refund you immediately as you email to us. And we are in here for you 24/7 for anything you need!
Weather Updates, SOS signal, and emergency weather information plus a dependable power source will prove to be invaluable in the face of mother nature’s fury!
As a responsible Brand, We Always be with you to defeat the monster disasters.
Always Be Prepared for the Worst but Hope for the Best! – Scroll Up to Click to Purchase
4.5 out of 5 stars
1,227
4.6 out of 5 stars
14,324
4.5 out of 5 stars
19,139
4.5 out of 5 stars
7,398
3.8 out of 5 stars
37
$35.90$35.90 $28.72$28.72 $18.90$18.90
Battery Capacity
6000mAh 4000mAh 2000mAh 2000mAh 8000mAh
Reading Lamp
None
Flashlight
3 Modes Flashlight 3 Modes Flashlight 1 Mode Flashlight 1 Mode Flashlight 3 Modes Flashlight
Charging Method
Solar Powered, Hank Crank, USB Port, Rechargeable Battery Solar Powered, Hank Crank, USB Port, Rechargeable Battery Solar Powered, Hank Crank, USB Port Solar Powered, Hank Crank, USB Port, AAA battery Solar Powered, Hank Crank, USB Port
🔋 6000mAh RECHARGEABLE BATTERY ★ This emergency weather radio can be used as a 6000mAh removable power source to provide enough emergency power for more than one cellphone to make an important call to family or contact assistance in an emergency. The MD-090P emergency radio is the best cost-effective in this market.
📻︎ 3-BAND EMERGENCY RADIO ★ The weather radio receives 7 NOAA broadcasts and accesses the AM FM channels, it professionally broadcasts the latest weather and all danger information for your area, such as hurricanes, wildfires, winter storms, and more. Gain critical time for you to be fully prepared in advance and keep you and your family safe with this emergency crank radio.
💡 3 + 2 MODE EMERGENCY LIGHT ★ This super-bright 3-mode flashlight on the emergency radio has a maximum illumination range of over 10 meters, farther than most other solar-powered emergency radios. In addition, this emergency radio has a 2-mode reading lamp with a motion sensor that can be turned off manually and automatically, which will greatly help save power.
⚡ 4 WAYS TO KEEP POWER ★ This emergency weather radio combines a rechargeable battery, micro USB charging, solar charging, and a hand crank. USB is the fastest way to recharge on a daily basis. The solar panel and hand crank extend and maintain the life of the rechargeable battery, typically used during storms, to maintain all functions of the emergency radio.
☺️ FRIENDLY CUSTOMER SERVICE ★ In the past years, Our emergency radio has helped more than 10,000,000 USA Civilians to live through hurricane, tornadoes, and snowstorm seasons, like “Dorian”, “Harvey, “Irma”, etc. We offer an 18-month warranty and lifetime technical support for this emergency weather radio. If you are not satisfied with this weather radio, please find us through “Buyer Message”. Our customer service is available 24/7 to help you with anything you need!
