Price: $11.99
(as of Aug 22, 2024 05:30:17 UTC – Details)
ADRIMER REUSABLE ICE PACKS FOR LUNCH BAGS/COOLERS
ADRIMER is a new brand that resulted from a simple need: Provide you with truly reusable ice packs for your lunch bags/boxes, coolers. It is designed for your husband who is working outside all day, for your kids who always take his cute bento boxes to school, for your family to camping, hiking, riding, fishing or go to the beach. We hope ADRIMER Ice Packs will be around as long as you need them.
Perfect ICE FREEZER PACKS
Superior Cooling
ADRIMER Ice Packs uses non-toxic, high-performance “phase change materials“ to provide a higher energy concentration for sustained cooling at 18° F (-8° C).Perfect chillers for everyday use in coolers to keep goods cool when you’re on the go
Reuse Over & Over
There is an initial “just add water” setup to change the dry powder to gel, then put the cork in, and they can refreeze and reuse over and over again!Our cooler packs are made with aluminum and polyethylene to ensure durability of the packs and reinforced with thin nylon to help strengthen the pack
Lasts Longer
Ice packs for coolers last much longer than ice features a maximum surface area for faster, colder, longer cooling, and can be used with ice in ice chests and coolersPerfectly freezer packs for your family to keep sandwiches fresh for longer, drinks cold without any ice-melted problems.
Frequently Asked Questions(FAQ)
—Are these reusable?—They are reusable. There is an initial “just add water” setup to change the dry powder to gel, then you throw them in the freezer for several hours and they are ready for use.—How long do these packs stay frozen for?—Many factors can determine how long the packs will last. Some of them are: quantity of packs to the size of the cooler, number of items in cooler relative to the cooler size, the temperature of cooler when packs are introduced, the temperature of cooler contents the packs are put in, ambient temperature, and how often cooler is opened/closed.—Is it necessary to freeze for 24 hrs each time you reuse them or just for the initial time?—No, it is not necessary to freeze 24 hours every time. We recommend it for the first freeze. If the pack is still cold or frozen in the center after your first use, it requires less freezing time for subsequent uses.Can these be stored outside the freezer between uses? –They can be stored in the freezer or they can be laid flat and stored in a cool dry place. Just keep them out of reach from kids or dogs.
4.3 out of 5 stars
119
4.3 out of 5 stars
192
4.3 out of 5 stars
192
4.3 out of 5 stars
119
4.3 out of 5 stars
192
4.3 out of 5 stars
192
Size
M: 9.8″ x 9.8″ M: 9.8″ x 9.8″ S: 7.5″ x 6.5″ S: 7.5″ x 6.5″ 2S + 2M 5S + 3M
Quantity
3 Packs 8 Packs 4 Packs 6 Packs 2+2 Packs 5+3 Packs
BPA-Free
Long-Lasting
Reusable
Features
Keep Food Fresh and Drinks Cold Keep Food Fresh and Drinks Cold Keep Food Fresh and Drinks Cold Keep Food Fresh and Drinks Cold Keep Food Fresh and Drinks Cold Keep Food Fresh and Drinks Cold
LONG-LASTING & STRONG COOLING: ADRIMER ice packs for coolers are colder than ice at 18° F (-8° C), can keep your favorite sandwiches and drinks cold up to 24 hrs without facing the messes of melted ice, great for freezer-to-lunch bags trips or any outdoor activities, such as picnics, fishing, camping
SAFE & NON-TOXIC: These freezer packs are made of 100% BPA free food-grade materials, filled with non-toxic materials, durable, portable and easy to clean, can be used immediately and quickly transfer energy, best choice for your family to picnics
REUSABLE ICE PACKS for COOLER: These cooler ice packs are lightweight and reusable, great ice alternative, save your money on pounds of ice cubes. Just add water to change the dry mixture to gel, then put the lunch box ice packs to the freezer for one night and they will be ready for use
EASY to USE: Each ice pack measures 9.8 x 9.8 x 1.0 inches, fits perfectly in cooler or lunch bags. Just add the appropriate water (28OZ water) with collapsible funnel, shake, screw cap, freeze until use. It is recommended to freeze for 24 hrs first time for the best effect , then 8-24 hrs is ok
MULTI-FUNCTIONAL ICE PACK: Perfectly pack lunch or use in large insulated coolers and totes, great for freezer-to-lunch bag trips or fits perfectly in ADRIMER Cooler Backpack as well as all types of lunch bags, box, coolers, breastmilk bags, or grocery totes. Ideal companion for your family every day use
