Price: $163.99
(as of Sep 30, 2024 03:00:19 UTC – Details)
Product Specifications
500W max load capacity: 200 KG
750W max load capacity: 300 KG
Product Includes
1x 500W / 750W Brushless geared motor
1x Motor controller
1x #420 Chain
1x Chain wheel (38 tooth)
1x No teeth freewheel
1x Freewheel adapter
1x Throttle(with key switch & voltage indicator)
1x LED headlight
1x Light switch
1x Brake lever
✅【Maximum Load 】Electric Tricycle Conversion Kit 750W Maximum Load: 300 kg/ 660 lbs; 500W Maximum Load: 200 kg/ 440 lbs; Suitable for tricycles/ rickshaws/ three-wheeled bicycles etc.
✅【Rickshaw Motor Kit Includes】1 x 500W/750W Brushless Gear Motor; 1 x Motor Controller; 1 x #420 Chain; 1 x Sprocket (38 teeth); 1 x Toothless Freewheel; 1 x Freewheel Adapter; 1 x Throttle (with key switch and voltage indicator); 1 x LED Headlamp; 1 x Light Switch; 1 x Brake Lever; No Battery.
✅【High Speed Brushless Motor 】The bike conversion kit motor can reach 750W / 500W power output to ensure efficient work. Voltage: DC 48V.Brushless geared electric motors are usually quieter, smaller and lighter.
✅【Overheat Protection】 The brake lever can disconnect the power and brake during traveling. This saves energy and prevents the motor from overheating. The included “Torque Lever” ensures safe and stable operation of the bike together with the motor.
✅【Recommended Batteries】 The voltage of this motor kit is 48V and requires four 12V batteries or two 24V batteries. They have a recommended capacity of greater than 20AH when connected together.Batteries and battery charger are not included with this kit.
