Price: $19.99
(as of Aug 16, 2024 17:45:30 UTC – Details)
Weather Alert Radio with hand crank and flashlight
You can’t imagine what’s going to happen next. How important it is to give you advance weather notice and keep you safe. This emergency weather radio have weather alert, big LCD screen, auto scan, AM/FM/WB three bands, USB charging/hand crank power/solar power/3 AAA batteries power, 1W LED flashlight and bottle opener. Give you advance weather information alert before danger situation coming and keep you safe, also can stay with you for camping, hiking and other activities.
Feature
Auto Scanner
There are two type of selection for this weather emergency radio, it can auto scan the station in your area and you can also select the station by yourself.
4 Power Source
USB charging, hand crank, solar panel and 3 AAA batteries 4 power ways can power this emergency radio. Never worry about the power outage issue.
IPx3 Water Resistance
IPx3 water resistance allows to you carry this hand crank radio in outdoor.
Feature
2000mAh Power Bank
This emergency weather radio can be worked as a 2000mAh power bank and charge your USB device anytime.
Portable Size
6.26*3.19*1.85 inches portable size super suitable for camping, hiking etc… carry it anywhere.
Bottle Opener
There is a bottle opener in this weather radio allows you use it in the party time. Household must have it. Enjoy your patry time with this emergency radio.
Multifunction Emergency Weather Forecast
Get this digital emergency radio, you will be grateful you have this hand crank solar radio in your package when the emergency siutation comes.
【2022 UNIQUE WEATHER ALERT RADIO】: A real and reliable emergency radio should be included the weather alert function, which can make a loud warning and remind you before the hurricane,tornado and earthquake coming. Better to keep you and your lover safe with this AM FM NOAA radio. Never worry about the emergency situation happens.You will get such a weather radio with excellent reception, best crystal sounds and total 7 noaa channels in US for outdoor activities and emergency.
【LARGE DIGITAL LCD SCREEN】: To make the user to know the accurate channel more clearly and choose the correct station, we design a 1.4*1.7 inches digital LCD screen in this weather alert radio. All information of the AM FM band, frequency, battery capacity, voulme show on the LCD screen. You can know more about the state of crank radio. This emergency weather radio also has the auto scan and the backlight setting, allows you to operated easily and use even at night.
【ALL EMERGENCY FUNCTIONS REQUIRED IN ONE】:Both AAA batteries and 2000 rechargeable battery two types of pwer source can be used as power bank in this solar radio, which can charge your USB devices. SOS alarm and the 1W bright flashlight is very useful in outdoor emergency situation. This hand crank radio is also support the standard earphone(earphone not included). In consideration of its practicability, we mix the bottle opener in this solar crank radio for camping or using in home.
【4 POWER SOURCES WHEN YOU NEED IT】: Hazard weather always lead to power outages and you would like to have this weather emergency radio. Hand crank and solar power these two power sources can power the weather emergency radio when you need in emergency. USB fast charging is the main power way in daily use. 3 AAA batteries can be powered and you can find it in any stores and supermarket. Power up anytime and anywhere.
【COST-EFFECTIVE WEATHER RADIO】: You can not imagine such a 6.2*1.85*3.2 inches digital weather alert radio which included the a large digital LCD screen, weather alert, flashlight, SOS alarm, radio and 4 power sources. Keep one crank solar radio can replace all these things. You will find that this weather noaa radio has been with you through every bad weather, also a good partner of camping and other outdoor activities. Our world customer service is waiting for you 24/7 anytime.
